Tailgate Strap Problem
Old May 21, 2013 | 12:50 PM
Jmcnamara74's Avatar
Default Tailgate Strap Problem
I am running 35 inch Nitto Trail Grapplers and last week while gently opening my tailgate the metal strap that connects the tailgate to the inside panel snapped like a twig. Any suggestions on where to find a replacement is greatly appreciated. Thanks
Old May 21, 2013 | 01:11 PM
ronjenx's Avatar
Are you talking about this thing? If so, did yours break, or just pull out of the fixture inside?
Old May 21, 2013 | 01:16 PM
Blackmetal's Avatar
Lovin my '07
Old May 21, 2013 | 03:03 PM
jeeeep's Avatar
pic of the problem would be handy
Old May 24, 2013 | 07:08 PM
Ronjenx, that is exactly what I am talking about. Mine broke off and pulled out of the fixture inside. Where can I find that replacement part? Thanks a lot for your help I really appreciate it.
Old May 24, 2013 | 07:18 PM
ronjenx's Avatar
The part can be bought from the dealer. I think it's around $35.
It's possible to pull the linkage out of the fixture without having broken anything.
Are you sure yours is broken?
The second picture in this thread shows what the end of the link looks like: https://www.jk-forum.com/forums/jk-w...trofit-221117/
Old May 24, 2013 | 07:26 PM
Yeah it definitely cracked off. I took it to the dealer (Mancari's in Chicago), but they told me it was not covered under the warranty because I installed 35 inch tires. From what I can tell this is a common problem even with a factory spare. I might just leave it off at this point.
Old May 24, 2013 | 07:37 PM
ronjenx's Avatar
The way the thing is designed, it doesn't serve as a travel limit, so I don't see how the heavier tire would be a factor.
When I was installing mine, it pulled out of the fixture without breaking anything. It was tricky getting it back in.
At what point on the rod did yours break? (I have assumed it was the hidden end. Maybe yours broke at the tail gate end?)
Old May 25, 2013 | 08:30 AM
DEADRABBIT31's Avatar
The had the same thing happen to me on my 2013 2 door Rubi with stock tires so that B.S. the dealer gave you about your 35's is lame. I couldn't have opened it any slower and it snapped out ! I haven't had time to bring it back to the dealer yet but I'll let you know what they tell me OIIIIIIIO
Old May 26, 2013 | 07:29 AM
BigRich's Avatar
Originally Posted by Blackmetal
Lovin my '07
YEP! Nylon strap for the win! :p
Sent from my iPhone 4S using JK-Forum
