Sponsored by:
Sponsored by:
Wandering after leveling kit install
Old 06-30-2013, 05:20 PM
RenegadeUL13's Avatar
Default Wandering after leveling kit install
I recently installed a Teraflex Performance Leveling kit.* After doing so I had the vehicle alignment done.* I've been experiencing a fair amount of "wandering" since installing the leveling kit.*
I'm curious if anyone else has experienced the same thing and what if anything can be done to correct the problem?
-Would longer lower control arms correct the suspension angles?
THANKS!
Sent from my DROID RAZR using Tapatalk 2
Old 06-30-2013, 05:32 PM
BlackRockBurner's Avatar
Normally a level kit should not decrease caster too much. See what the angle is: between 4 & 6 is the average for lifted rigs. Too high and the pinion angle may make the driveshaft buzz. So yes, front lower control arms can dial it in.
Try lowering tire pressure first.
Old 06-30-2013, 05:51 PM
Ok, I'll try that. How do I measure the angle? Thanks for your help.
Old 06-30-2013, 05:53 PM
jeeperjkjeeper's Avatar
what is the reading from the alignment shop on your toe setting? JK's handle best when they are set to 1/16-1/8" toe IN.
Old 06-30-2013, 06:55 PM
That sir, I do not know. But I have a pretty good rapport with the garage so I'll run that by them come next oil change. Thanks!!
Old 06-30-2013, 10:11 PM
Fugg it's Avatar
X2, lower ur air pressure
Old 07-01-2013, 02:23 AM
Kojack's Avatar
Lower your air pressure. Also, if your shocks have a bunch of miles on them that could do it too. Mine had 92k on them and I noticed my jeep wandering. Swapped to Monroe reflex and made a huge difference.
Sent from my SGH-T899M using Tapatalk
Old 07-01-2013, 06:09 AM
Will do, today. What should I be running? Stock Goodyear Wranglers I have them at 35 (ish)
Old 07-01-2013, 08:24 AM
Try 28lbs and see what it does for your tracking. Then do a chalk test on the tires to check for wear. Find that compromise in air pressure.
Old 07-01-2013, 08:28 AM
Rule18's Avatar
You could also try setting the pressure to factory spec since they're stock tires. Sometimes it's good, sometimes not.
Quick Reply: Wandering after leveling kit install
