Teraflex 2.5 lift question
Old May 30, 2012 | 07:18 AM
Willis19's Avatar
Default Teraflex 2.5 lift question
Have a tf 2.5 lift is it possible to put long arms on a lift this small someone said you might have to go higher and if I do how much high should I go before I have to start messing with the steering components etc.
Thanks appreciate the help
Old May 30, 2012 | 07:25 AM
notsoricer's Avatar
So your goal is to go high enough to have to add more components? From what I've seen and read, 3" is the starting point for that. That's when you start adding drive shafts, arms, steering, and so on..
Old May 30, 2012 | 07:36 AM
Willis19's Avatar
So basically can I just change my coils to go to 3 then start adding more components
Old May 30, 2012 | 08:09 AM
TeraFlex's Avatar
Sponsoring Manufacturer
Yes you can install a long arm with a 2.5" kit, but that is way over kill. Around a 4" kit is when you need to address the steering components.
Old May 30, 2012 | 08:11 AM
notsoricer's Avatar
Technically, yes. But make sure your shocks are compatible and your sway bar links are long enough then go from there. Also, you're gong to need new bumpstops too.
