teraflex axle sleeves question
Old Jan 26, 2012 | 11:11 AM
DanieltheManual's Avatar
Default teraflex axle sleeves question
saw the product on Northridge,
anyone have these? cant find any write ups and was wondering about them, how hard is the install ?they work on d30 right!?
reviews or experience will be helpful, thanks
http://www.northridge4x4.ca/proddeta...rod=TF-4990700
Old Jan 26, 2012 | 11:46 AM
jtjk's Avatar
A few companies make them, all are.lretty much the same. They are good insurance if you are running oversized tires. install requires removing the axle shaft, inserting those, driling a couple holes in the hkusing and then rosett welding the holes closed. Not sure if the order I listed is right.
I guess if you can weld well it would not be all thay hard....just time consuming
There is a vidoe done by evo and project jk that expains the install. Its on you tube
