teraflex budget boost
Old Mar 12, 2010 | 11:09 AM
bigjeepmm's Avatar
Default teraflex budget boost
i have the 2.5" TF BB. does anyone have pictures of how the rear swaybar links need to be placed ; direction of bolt head/ inside or outside..etc
thanks
Old Mar 12, 2010 | 11:19 AM
falconfixer's Avatar
This work?
Old Mar 12, 2010 | 11:24 AM
zerodown's Avatar
To the far right..... upper end of passenger side sway bar link as seen from the rear.>>>
Between the shock can and the shock mount is the lower end of the same link.>>>
Both ends get mounted on the INSIDE of the mounts. Away from the wheel.
Old Mar 12, 2010 | 11:27 AM
zerodown's Avatar
NOTE: Put the sway bar links on before your shocks. If you don't, the can will get in the way of the bolt for the sway bar link.
Old Mar 12, 2010 | 11:29 AM
Some say inside, some outside, eh no issues here with it on the outside
Old Mar 12, 2010 | 11:34 AM
zerodown's Avatar
I'm pretty sure the installation instructions say inside, but hey, you can't argue with success.
Old Mar 12, 2010 | 11:37 AM
Cant argue with distructions either. I didnt get any with mine, put them on like the stockers and have no issues. bigjeepmm, you didn't get any instructions?
Edit: I followed These instructions when installing mine.
Old Mar 12, 2010 | 11:46 AM
zerodown's Avatar
Pretty tough to argue with a WOL write up too! I learned how to do everything to my Jeeps @ http://www.4x4xplor.com/mods.html
WAY better than the instructions that come with lift kits.
Old Mar 12, 2010 | 12:12 PM
bigjeepmm's Avatar
Default thanks
thanks i already installed the lift just looked wrong with the bolt thread facing the wheel. thanks
Old Mar 12, 2010 | 12:18 PM
TeraFlex's Avatar
Sponsoring Manufacturer
Woah there. You have a old style rear trackbar bracket setup. PM your name/address to me.
Rear swaybar links should be mounted inside top and bottom. Now you can mount them outside top/bottom if you have proper backspacing on the wheels.
