Teraflex control arms
Old Dec 25, 2012 | 06:08 PM
aftermath's Avatar
Default Teraflex control arms
I am about to order some front lower adjustable control arms for my 2013 jku. Any tips or tricks on installing them? Any help or video links would be great.
Old Dec 25, 2012 | 06:20 PM
HLKSTER's Avatar
You can do a search on here and also check YouTube they probably have an install video,
Old Dec 25, 2012 | 08:36 PM
T&ERun's Avatar
Are you lifted? If so how much? You'll have to find out what legnth to run. The TF arms usually come with a chart to tell you the length (depending on how much lift you have of coarse). Raise jeep off the ground (by lifting on frame). Change out one arm at a time. Remove the arm, install the new arm on the frame side first and then the axle side. The bolt more than likely won't line up on the axle end when you do this. Use a jack to lift on the axle at this point. You can jack on the rear of the "pumkin" or front of the "pumpkin" to help you line up the bolt hole. Many people get the frame side in first and then fight like hell to get the axle end to line up. I've seen guys use pry bars, ratchet straps, etc. By just jacking on the differential just a little bit (usually on the pinion side) it lines the bolt up perfectly. Easy.
Old Dec 25, 2012 | 08:45 PM
aldaman's Avatar
x2, on the instructions above but I was able to change mine out w/out having to lift/jack up the frame. The jeep was still planted on the ground with all 4 wheels, I just changed one side at a time...You can always use the 23" length as a starting point and do the fine tuning from there. Don't forget to use the lock tight when you are all done and the grease fitting should be oriented at the top & not in the bottom, if so it will just get ripped off when offroading...
Old Dec 25, 2012 | 09:01 PM
hooper's Avatar
If u have a lift under 2.5" you can measure them the same a stock length and replace one at a time. A lift over that use the length in the instructions. I did not have to adjust for castor with my 2.5 TF lift. It road fine after the install.
Old Dec 25, 2012 | 09:09 PM
SWRUBI's Avatar
Why bother with changing out the arms if the length remains the same as stock?
Old Dec 25, 2012 | 09:35 PM
aldaman's Avatar
Most aftermarket arms are beefier / solid or have thicker DOM tubing rather than the stock hollow arms which allow them to take more abuse. Some of them have rebuildable joints, have Johnny joint or something similar which allows more flex/articulation due to more misalignment....
Old Dec 26, 2012 | 04:05 AM
aftermath's Avatar
I'm running 2.5 inch teraflex coil lift. With 18s and 33 toyo open country mt. I want to go with the Teraflex adjustable front lowers. Don't want to pay a shop to install if I don't have to.
