Teraflex Delta BBK
Teraflex Delta BBK
It looks like Teraflex has stepped up and expanded on their BBK offerings for our JK's as well as the JL and they listened to what many of us have been saying by allowing us to purchase aftermarket replacement brake pads when that time comes.
4 Piston calipers, 14in front rotors, and an easy brake bleeding check valve on the calipers. Seems like a winner and welcome addition to our JK BBK options.
Facebook Post
It makes me almost wish I didn't already have a big brake kit installed. It sure does look like a very attractive option. That check valve bleeding seems to solve a lot of problems for many not comfortable with bleeding brakes as well. Now that's engineering I can admire. Identify a concern/problem and create a solution for it.
ahhh, I'm seeing $2100. For that price they dang well better be nice. A lot like the TF semi to full float conversion....seems awesome till you see the sticker price.
Has anyone found performance related specs yet? I'd be curious to see how the different versions of TF brake kits compare to each other.
13.3" Rotor-Only
13.3" Rotor w/2-piston caliper
14" Rotor w/4-piston caliper
13.3" Rotor-Only
I was thinking kinda the same....that really this would be 40"+ tires, but those are usually on tons, but that 1-ton axles already have considerably better/larger brakes already. The brakes on a UD60 have no issues stopping a heavy jeep on 40s, I know that for certain.
Hopefully we see some reduction in price. That is a pretty steep price, while also taking into consideration that you would likely need to get the Mopar MC and Booster to go along with it. Someone at TF must have looked at DT's BBK which originally went for $1600 and thought, if Jeepers are willing to pay $1600 for that kit, then this kit which additionally includes 4 upgraded calipers must be worth at least $500 more.
They mention it uses Toyota pads. I'm really wondering if the calipers started off as a Toyota caliper or if this was a ground up development? If ground up, then that price makes sense. If it came from Toyota, I have some inside connections I could likely find out more.
