Teraflex Delta BBK
It looks like Teraflex has stepped up and expanded on their BBK offerings for our JK's as well as the JL and they listened to what many of us have been saying by allowing us to purchase aftermarket replacement brake pads when that time comes.
4 Piston calipers, 14in front rotors, and an easy brake bleeding check valve on the calipers. Seems like a winner and welcome addition to our JK BBK options. Facebook Post |
This looks really good.
Originally Posted by jedg
(Post 4338057)
Yup... looks to be a good approach to two problems... braking and bleeding.
ahhh, I'm seeing $2100. :eek2: For that price they dang well better be nice. A lot like the TF semi to full float conversion....seems awesome till you see the sticker price.
Has anyone found performance related specs yet? I'd be curious to see how the different versions of TF brake kits compare to each other.
13.3" Rotor-Only 13.3" Rotor w/2-piston caliper 14" Rotor w/4-piston caliper |
I think this is aimed at the tons crowd more than anything. Bolt patterns are 5x5 and 6.5x8.
Originally Posted by SoK66
(Post 4338136)
Hopefully we see some reduction in price. That is a pretty steep price, while also taking into consideration that you would likely need to get the Mopar MC and Booster to go along with it. Someone at TF must have looked at DT's BBK which originally went for $1600 and thought, if Jeepers are willing to pay $1600 for that kit, then this kit which additionally includes 4 upgraded calipers must be worth at least $500 more. ;)
They mention it uses Toyota pads. I'm really wondering if the calipers started off as a Toyota caliper or if this was a ground up development? If ground up, then that price makes sense. If it came from Toyota, I have some inside connections I could likely find out more. |
