Teraflex performance leveling kit plus puck leveling kit, whats need?
I have the puck leveling kit as of now, but i was thinking of adding the performance kit plus the Spacers i have now(-1 spacer in the front) for a 2.5in lift. I was gonna move my rear sway bar link to the front, take the extended sway bar link i got with the leveling kit and move it the rear. Get bump stops and shock extensions and done! anyone see any problems with this thanks.
Interesting. I briefly thought about doing this this too. I already have the spacer leveling kit installed also.
Aside from checking brake line lengths, it might be a good idea to upgrade your stock shocks to ones made for a 2.5" lift.
I was gonna buy the shock extenders that come with the 2.5bb, The only problem im seeing is i think ill have to buy a new rear sway bar link. But it will cost under $400 and it will be a 2.5 lift with new coils so i dont think its a bad deal.
i think i have everything figured out, i just have two more questions. Would i need to use track bar brackets? and can someone give me the measurements of the sway bar links that come with a tf lift for the rear end? thanks
I have the performance leveling kit (coils) and kept a 1" TF puck in the front also. No shock mods and I put JKS quick discos on (2-6" lift set - I had to set them to as short as they go but the swaybar arms are level with ground. Shocks might help for flex - don't know yet. No problem driving around though.
