TF 2.5" lift installed!!
I'll try and get pictures tomorrow but I got it installed with the AEV Geometry brackets, man it rides great and it's not darty at all. It rides better than it did when stock. I'll put about 500 miles or so on it and go back over the bolts and check the tq again but go to get the Cooper Discovery Pro STT 295/70/18's on this evening after work. Can't wait to see it with the tires.
I got the $748 kit that came with the TF shocks etc. along with the TF stabilizer shock , added the AEV brackets for good measure and glad I did. The steering is just a hair to the left but a quick trip to the alignment shop will cure that.
Now my friends hollering detachable sway bar links, do we need them?
Essentially, detachable links eliminates the sway bar as being the 1st limiting factor of suspension downward droop, where your shock length now becomes the next suspension flex limiter. Which at the end of the day, helps to keep your tires on the ground, which increases off-road capabilities by having more tire traction on the ground in off camber scenarios.
So do you need them? No. Do you want them for off-road capability performance? Yes. Do you want to have your links disconnected while driving on road? Absolutely Not.
yup^^^. If you're gonna wheel, quick disconnects are worth the money. Disconnect in a few clips while you're airing down and off you go. Nothing worse than hitting a trail with someone and as you're airing down look over and see them on their back fiddling with wrenches. You can make your own for cheap, but spending $160 or whatnot on some nice ones is worthwhile.
"The steering is just a hair to the left but a quick trip to the alignment shop will cure that."
If you're saying your steering wheel is a bit to the left, you can fix this yourself. Adjust your drag link (two 15mm bolts).
If you didn't make any adjustments to your tie rod, you won't have anything that the alignment shop can do for you (unless you have adjustable control arms and they are willing to make adjustments to the control arms). From what you said above, I'm guessing no adjustable control arms. And, since you said it drives fine, save the cash from an alignment and use it for something else. Adjust your drag link and you're good.
My friend wanted to check the height of his jeep after he installed Rubicon Springs from a 2017 Unlimited 4dr. He's about 1/2" down.
Here is a couple of pictures I took after getting the tires on.
looks great. I have the same TF lift, and am happy with them too. Glad to hear the AEV brackets worked out. I had the Rancho geo brackets, but I got too much caster (at the lowest hole), which rode fine, but I didnt like that. so I ended up switching to TF sport flexarm front LCA, and the caster is just right.
