Are they necessary?
finally somebody sugesting rancho i thought i was the only one with a rancho sport lift. this is the best lift i've seen for the monney. it comes with an extension for your lower front arms wich works a lot like a long arm system. amazing flex. way more than a regular short arm system.
I had it aligned about 2 weeks before I lifted. After the lift it was still aligned well. My axle is off-center about 1/2" but I don't think that'll have a bearing on the alignment once it comes back to center after the trackbar install. I did center the steering wheel but that might've been off before the lift... can't remember.
So, after your lift drive and see how things feel. If you're pulling one way or the other, check your geometry. If you're in check, bring it to the dealer and have them align you.
Well my dealer installed the lift for me and did a great align, drives better than stock, steering wheel is centerd, and its not pulling.............
i hope it stays like this after i install and adjust the track bars
yellowruby. I guess if I had to say something I don't like .would be that is harder to install than a regular lift. but everything else works pretty good it drives better than my friends jeep (superlift kit) it comes with a pitman arm and bracket up front wich works better than I thought. and all the pieces seem very strong. I went with rancho because they had it at my local store, in the past I've had many different kits in different jeeps and trucks, but this is the first time I can say I'm totally happy about it.
