Things I learned New Year's Day.
1) When fording a stream, underwater rocks will cut right through the sidewall of 32" tires.
2) the Jack that came with the Jeep does nothing when you have 4" of lift.
3) the old worn out spare that the dealer left on the back will cause death wobble above 45mph if it is not balanced properly.
4) puncturing a sidewall and having an old worn out spare gives you a valid reason to finally get 35s!!!!!
That spare tire is where it's at, man. It's such a b*tch to shell out for a matching tire and wheel for your spare when you go to upgrade, but it's worth it in spades when you need it on a trail.
Sounds like an adventure! Definitely get something with a stiffer sidewall on your next purchase.
