Those with the Teraflex 2.5 coil kit....
how long have you had it and are you still happy with it? Would you recommend it? I'm looking to go to 35s next year and this is a kit I'm looking at. Looks fairly complete & a decent value. I would be running this on a fairly light two door btw.
Thnx in advance.
Thnx in advance.
I have it and I'll tell you I like it. But if I were to go back and do it over I would go with the 3" for more clearance on the 35's when crawling. Love the company thought and they have great products.
I have had mine on for over a year and it was used prior by a buddy. His was in a 4 door and mines only a 2 door. I gained about 3 1/2" down to about 3 after bumpers and a winch.
Thanks for the replies...
I appreciate it. I've been looking at flat fenders as well. Will probably install them too. Anyone have issues with sagging?
Not sagging over time, but weight. I've had to replace rear springs with OME HD when loaded expedition style (very heavy). Pull hardtop and expedition gear, and I also swap TF springs back in. Rubbing with 35s corrected by trimming rear pinch seams.
TeraFlex 4dr 2.5 lift with TeraFlex 1" spacers f&r. Used spacers to make up for weight from bumpers, tire carrier, winch, rails and flares.
I would've went with the 3" coils but I've seen tons of 2dr lifted over 5" from the 3" coils. I want to be lower to ground with bigger tires. 37s will fit with zero issues
Had the 2.5 coil. Also added a 1" puck in the front. Added front lower ca's and the monster trackbar. Added bushwacker flats. I had 0 problems on the trail with 35" toyos on AEV wheels with no spacers Recently upgraded to metacloak gamechanger 3.5, to make the jump to 37s. I sold the old lift and tires to a buddy and it's still going strong.
Old vs New, also summer mode vs winter mode😜
That looks great!
