thoughts on a lift with spacers?
Old Oct 13, 2010 | 01:35 PM
jdmda9noke's Avatar
Default thoughts on a lift with spacers?
heres my jeep specs
2007 wrangler X unlim
6 speed manual
i have a 2inch rc spacer lift now
i have a zone 3 inch lift sitting around and was think about just adding it along with the spacers, i know ill need C arms for sure
would i need new Drive shafts?
and which C arms do u recommend front uppers, lowers, rear uppers, lowers
Or if oyu just wana talk me out of it, all imput welcome thanks
Old Oct 13, 2010 | 01:39 PM
TeraFlex's Avatar
Sponsoring Manufacturer
Start off with a set of front lowers and rear uppers. Do you have a adjustable front trackbar? Also do you have longer brakelines, swaybar links and the right bumpstops?
Old Oct 13, 2010 | 01:47 PM
jdmda9noke's Avatar
Brake lines-check
sway links-never had any
adjust track bar-got one from you guys
Old Oct 13, 2010 | 02:21 PM
nthinuf's Avatar
Open up the FAQ's (top of this modified area)
Lots of great info, but read these specifically:
Q: What are all the components that I will need with a 4" lift?
Q: What is Caster? How much do I need?
Q: Are new driveshafts needed after installing a lift?
Q: I want to run larger tires and want to know what is the bare minimum I should do to beef up my front axle?
Q: What is the most common reason for front axle breaks?
As you go higher and higher, you need more and more components to get you back to a stock ride. So, do you 'need' 5" for a new set of 40" tires? (and are willing to drop the money to get there) Or do you just 'want' 5", and don't really realize yet the can of worms you'll be opening...
Old Oct 13, 2010 | 02:26 PM
jdmda9noke's Avatar
got a set of 37's sitting in my garage, money not really a big deal, i thought it would be a fun and different project
