thump sound from rear driver side tire post lift
Just installed a rock krawler 2.5" stock mod with bilstein 5100s.
I have been hearing this frequent thump noise from the rear driver side tire and have no idea what it is Only occurs on small.bumps in the road. Nothing seems loose...I checked the trackbar no problems |
Post a few pics. Could be the coil is bowed out, or the link is contacting the rim, or any number or other things.
Originally Posted by nthinuf
(Post 2139391)
it almost sounds like it is coming from the rear door or below the door. Gonna take the door off as well and drive around to rule that out... It only started after installing the lift so i doubt it is the door. It is getting worse though, it is starting to sound like something is going to fall apart when i hit bumpy terrain. Bit worried. It kind of makes that sound like a tire dropping in and out of a small pothole. That "dum, dump" type sound. But over and over. This morning i loosened and re-torqued the rear trackbar and control arms... pretty sure i didnt miss anything. I did not re-do the links. |
I had the same issue after I installed the Tera Flex 2.5 coil lift. I tracked it down to the door latch. I put some electrical tape around the striker and there has been no more noise! I wish I could correlate the door to the lift but the only thing that comes to mind is the new ride is stiffer and might have amplified the door latch noise.
I hope that is all there is (east fix)! |
Originally Posted by Trooper1276
(Post 2142523)
Well i adjusted the striker because the door apparently was not even lined up with the tub.
Still made the noise. I just now wrapped tape around the contact point, but have not tested it yet. I did notice that when i close the door, it basically rips the tape up. Did i put too much? |
Originally Posted by lopezv123
(Post 2142881)
This is a known problem with the JK. The thumping is coming from the driver door hinge at the B pillar. Chrysler has a TSB on it. They just load the hinge with some sort of special heavy grease to fix it. Had mine done 2 weeks ago. So far so good.
I wrapped the rear latch with tape, have not driven with it yet. I am gonna take the doors off as soon as it is not raining and i can truly rule out if its the suspension or doors. |
(Post 2142911)
it really sounds more like its coming from the door, near the floor or latch. It just worries me because it only started after installing my lift. It almost sounds too loud/interior to be from the suspension though.
(Post 2142916)
sorry, I meant the latch, not the hinge.
Do you have a link to the chrysler TSB I wanna bring it in. I feel ridicclous having electrical tape on my doors. |
