Sponsored by:
Sponsored by:
Changing out trac bar and LCA bolts.
Old 03-03-2012, 05:20 AM
TONKA TOY's Avatar
Default Changing out trac bar and LCA bolts.
I just got my new bolts from Northridge and want to get them changed out this week. Can I replace them with the tires on the ground or do I need to lift it to take pressure off?
Old 03-03-2012, 05:25 AM
Saharaunlmtd's Avatar
You can do them with the tires on the ground as long as you don't do them all at once.
Old 03-03-2012, 05:28 AM
jeep2007's Avatar
No need to remove the tires. Do one arm at a time and once done bounce the front to help settle it before torqueing. Support the axle when doing the track bar with a jack.
Sent from my HTC Liberty using Tapatalk
Old 03-03-2012, 07:29 AM
TONKA TOY's Avatar
Thank you!
Old 03-03-2012, 07:31 AM
JKAbomb's Avatar
Changed mine out last weekend. Was very easy
Old 03-03-2012, 07:34 AM
RodRecket's Avatar
good info, should be getting mine in the mail this week
Old 03-03-2012, 08:09 AM
dan3jeeps's Avatar
Are you guys torqing the bolt head instead of the nut?
What sized wrench are you using on the factory bolt/nut? 20 mm? 21 mm?
Thanks.
Old 03-03-2012, 08:17 AM
Rubicron's Avatar
If at all possible, the nut should be the side you tighten from not the bolt head. As the bolt can bind against things and throw of your tourqe reading.
I'm not an expert, I just assemble municipal water systems for a living and happen to know a thing or two about tigthening bolts.....
Old 03-03-2012, 08:19 AM
dan3jeeps's Avatar
Doesn't seem like there is enough room to get the TQ wrench and socket on the nut side.
Is there? What am I missing?
Old 03-03-2012, 09:08 AM
OH9JK's Avatar
There isn't much room down there to begin with let alone getting enough leverage to put 125# of torque on those nuts.
Quick Reply: Changing out trac bar and LCA bolts.
