View Poll Results: tire size vs tire weight for axle health
Bigger tires/less weight is better
28
57.14%
smaller tires/more weight is better
3
6.12%
what the hell are you talking about?
18
36.73%
Voters: 49. You may not vote on this poll
Tire Size vs Tire Weight
so I am running 35's now and am thinking of 37's. I've already sleeved and gusseted the dana30 about as best I can do with stuff from EVO.
So here is the question, I look at my current combination of Mickey Thompson MTZ's (68lbs/each) on steel wheels (38lbs/each) and the total weight is 106lbs. If I get a 37" that is the same weight and then get aluminum wheels to wrap them around and net out a reduction in weight . . . am I actually doing better for my axles then sticking with heavier and smaller tire/wheel combination?
bummer, i was thinking it was a combination of both the weight and the size and by lowering the weight it would offset the added stress of the extra size. Guess I shouldda taken a physics class in college.
I'm no physics major either. Size, weight, rolling mass all have a bearing on performance. But you also need to know that for every take, there is a give. Lighter tires are probably less durable ( C rated ). Heavier tires add to the mass of the vehicle ( E rated ).
I have no idea.
Like I said. "No Expert Here". But you probably should make thes choices based on how you plan to use the vehicle. I would say that lighter is always better. But aluminum rims and C rated tires will probably not hold up very well on the trail.
As far as breakage I would say the taller tire would be worse.
If you double the weight of the tire you only double the stored energy. If you increase the the distance from the wheel center the stored energy goes up by the square of the radius change. So a tire that is twice as tall would have 4 times the energy.
When the tire looses traction and then suddenly grabs you are more likely to break a shaft with with the taller tire. If the taller tire gets bound up it has more leverage to twist and break a shaft also.
Originally Posted by JK-Ford
Like I said. "No Expert Here". But aluminum rims and C rated tires will probably not hold up very well on the trail.
