Took the “Sahara” and “Trail Rated” emblems off, how do I clean?
3M makes a adhesive disc remover that is round and rubbery that you put in a drill and spin off the adhesive without damaging the paint. 3M also sells double sided tape in different sized rolls that works great. I owned a body shop for many years and always used these 2 products for my emblem removal/attaching jobs. Cut pieces of the roll to overlap the emblem, leaving the protective tape attached. Then lay the emblem down on a piece of poster board/cardboard and trim excess with a razor blade or Exacto knife. Remove the protective tape and stick on to the vehicle. Measure using masking tape to give you a alignment guide, then after sticking the emblem back on, remove the masking tape. Viola!.
iloozealot (05-02-2019)
I've used Goo-Gone, followed by rubbing alcohol. Obviously once you're set.....nice wash, wax/paint sealer to protect in future.
