Took the JK on a 3 hour road trip felt like the Jeep was all over the road..
I have 4in lift with 18inwheels and 35 tires.. Everytime I would hit uneven pavment the whole Jeep would want to move in that direction. I would always have to make adjustments to the steering wheel to keep it moving straight. Anything I could do to stiffen up the steering wheel or the front end?
Some questions:
1) What lift do you have?
2) Stock trackbar (with bracket hopefully) or adjustable?
3) Drop pitman arm?
4) Are the front trackbar and draglink close to parallel?
5) What tire pressure?
3) Drop pitman arm?
Lots of threads on this. Tons of info. Rather than repeat, suggest that you search on "Bump Steer" and on "Adjustable Lower Control Arms" or "Adjusting Camber". Also, make certain that your tire pressures aren't too high--30 psi or even a bit lower for larger tires (I have 33s).
2. for the front I only have the stock trackbar.
3. Not sure what pitman arm is but me and a friend installed the lift kit it was used. Came with front springs, rear springs, shocks and rear trackball bracket.
4.I gotta look at this again
5. running 40psi all the way around.
1) your tire pressure is too high
2) you probably need either an adjustable front trackbar or a relocation bracket to restore the proper geometry and axle location.
3) and you probably need a drop pitman arm for the same reason.
Thanks for the quick response. Any brand recommendation for front adjustable trackball and drop pitman arm? Would I need to so an alignment again after these parts ?
You'll need to check the toe and center the steering wheel. You could do those yourself if you wanted to.
I do recommend having a shop do the pitman arm at least as they're a royal pain and torqued very tight. Give Jeff or Joe at 4 Wheel Parts on the South Loop a call, tell them I sent you and they'll hook you up. Ask for Jeff or Joe.
