TPMS Replacement ?
Old Jan 6, 2009 | 08:49 AM
sully151's Avatar
Default TPMS Replacement ?
What is needed to replace/exchange the TPMS sensors on to a new tire?
A tire shop is saying it will require new stems, and some sort of installation kit leading to a possible extra $60 in cost. Is this right? I have never dealt with TPMS so I want to make sure I am not getting screwed.
Old Jan 6, 2009 | 08:51 AM
wayoflife's Avatar
JK-Forum Founder
if you're keeping your factory wheels, i don't think you need to do anything. if you are getting new wheels, i believe you just need to take what's on your wheels now and install them on your new ones. unfortunately, i'm not 100% sure on this as i have an 07.
also, something you might want to consider getting is the new AEV programmer that northridge4x4 has been talking about as it will allow you to set your tpms to whatever psi you want - i.e. no more tpms light when running at lower psi
Old Jan 6, 2009 | 08:52 AM
eDiveBuddy's Avatar
60 bucks for the sensor and kit or just the kit??? The kit is only like 3 bucks!
Old Jan 6, 2009 | 09:02 AM
Matt08jk's Avatar
It is advised by the industry to purchase and install a TPMS sensor service kit after every time you remove and reinstall the pressure sensor to prevent air leaks around the sensor. If you are NOT changing wheels (i.e. not removing sensors), this is a bogus charge.
These are very inexpensive kits and comprise a rubber gasket, valve core, stem cap and stem nut. They are just over $3 at any NAPA store, part # 92-0210.
If you are just transfereing the sensors over, you will not need to "reset" the sensors and nothing else is required but this little kit and it takes 2 seconds. There is no need to track what corner each sensor is located.
Simply call B.S. on them if they say it will cost more than $20 to do the 5 TPMS.
Old Jan 6, 2009 | 09:10 AM
wrnglrguy's Avatar
When I got my new wheels, the tire shop simply took the sensors out of my factory wheels, and put them in my new wheels...at no extra charge. most new wheels need to have stems purchased anyways, so, you just simply use what is in your factory wheels. You DO NOT need to buy extra "stuff" to make them work.
Old Jan 6, 2009 | 09:20 AM
Matt08jk's Avatar
Yup, thats what my shop did too, but it was a 4x4 shop, not a shifty tire shop. I found out about the service kits after the fact.
Old Jan 6, 2009 | 09:50 AM
dburgette's Avatar
WOL...any word on the release date of this highly anticipated gadget.
Old Jan 6, 2009 | 10:01 AM
Ctimrun's Avatar
I just spoke to David and he said within the next month or so!
Old Jan 6, 2009 | 10:11 AM
kntr's Avatar
I wouldnt hold your breath since its coming from AEV.
Old Jan 6, 2009 | 12:19 PM
dadgummit's Avatar
Lets just hope because it does not seem like there are vary many alternatives
