track bar bracket
track bar bracket
How much difference will the ride be with a upper frame side bracket vs a lower axle side bracket on a 3" lift. Will it be that noticeable on the road?
Yup. Raising the axle side bracket is going to result in a higher roll center than lowering the frame-side bracket. Where you're going to notice that is corners and such when the body rolls to a side. It's not going to turn your jeep in to a POS, but it would be noticeable in more "aggressive" style driving as noted above.
This is one of those things that 95% of lifted rigs do a particular way for a reason. Do you want to be part of the 5% that doesn't?
I'd reverse the question. Is there some reason you're wanting or looking at lowering the frame side bracket instead? Are you looking at some lift kit that includes a lowered bracket?
You should go with the axle side bracket anyhow, but here is one more thing to think about. If you ever put adjustable rear control arms on to push the rear axle back against post-lift.....a lowered TB bracket is gonna come very close to interfering with the bump stop perch. If I recall correctly, I had to flip the frame-side TB bolt around cuz the bolt was banging on the perch under normal driving conditions going over a big bump. I can't imagine having that mount hanging lower than it already is.
Most people will add a simple bolt-on axle-side bracket. If you ever see yourself getting in to harder-core type off-roading, you might consider a good weld on bracket. The weakness of a bolt on is still the partial use of the factory TB bracket which is wimpy. I've sheared that factory bracket off before while using a cheap bolt on raised bracket. Not something that MOST people will encounter, but be aware that it can happen. Get a decent bracket that bolts to the lower control arm, the factory mount, and has a u-clamp around the tube as well if you can.
