Which track bar has 9/16" bolts?
My stock bar is messed up and I'm looking for an upgraded aftermarket one. Which ones are 9/16" at both ends? My first choice was JKS but I've read that the frame end is 14mm now. Is ******* a good bet?
Long term goals are to level the front end(1") and true 33" tires. Thanks. |
Originally Posted by Flip94ta
(Post 3238089)
I have the teraflex track bar and the 9/16 bolts fit fine.
1 Attachment(s)
Ive got the Rock Krawler Bomb Proof trackbar and it is 9/16 on both ends.
My Rock Krawler LCA's are 14mm on the axle end. Maybe that's what you were referring to.
No, I'm talking track bars. Thanks for the info guys.
I ended up ordering a JKS and a bolt kit from Northridge. The Rock Krawler showed a minimum 2 inch lift since its my commuter I'm never going that high. I appreciate everyone's input.
You should check if you have a local bolt store that sells the grade 8 9/16th bolts. I went to a local store here and got the exact same bolts/nuts/washers and only paid $22.00(after tax). Alot better that paying $80+shipping.
