Tuner for AEV 5.7 hemi conversion
I recently had an 08 Jeep Commander 5.7 hemi install with the AEV hemi conversion kit. It came with the AEV procal tuner but I was wondering if there are any other tuner compatible with the AEV ECU and programming that would let me adjust other areas of my hemi?
I would check the diablo trinity out.
You can contact shophemi.com they can convert your engine to vvt change cam and your ecu as well.. ;)
Hmmmmmmm, I'll check in to that. Thanks!!
Considering you are running AEV components, maybe you should ask AEV ?
I did just that but they are not parting with any info other than using their Procal :sad2:. They asked question like, "Do you wanna make more power or save gas?". Anyway I'm checking for other options that may be available.
The problem is that if you decide to make it vvt it is better to buy a used 6.4 hemi and sell your 5.7 ;) this is what i search for...
