So with the sensors removed, a ProCal can still turn the sensitivity of the reader to zero psi? I am getting new wheels and tires and was wondering if i should set the sensitivity to zero with the stock set up (sensors still on stock wheels) and then install new wheels with regular stems. I experienced the annoying chimes in a rental jeep last year and want to nip this TPMS thing in the bud..............
You will need to replace the TPMS when and if you sell the JK. This is considered a SAFTEY feature from the manufacturer! If you have it disabled and knowingly sell it you may open a big can of worms. And I see you (jk570) are from Pa. It may not pass inspection if it is disabled. Just things to think about.
2007 JK Unlimited 6 Speed 4.10 Gears 3 Inch BDS Lift 35x12.5x16 Yokohama Geolander AT/S 16x8 Cragar Soft 8 Black Steel Wheels Custom front Winch Bumper from RoundStar OffRoad Mopar Offroad Rear Bumper Oilpan/Tranny skid Plate by Skid Row JKS Quicker Disconnects Skyjacker Brake line extenders Skyjacker Adj Rear track bar High Clearance Adj Front Lower Control Arms by RocKrawler RocKrawler Front Lower Control Arm Mounting Bracket/Skid Plates Warrior Products Rear Safari Doors Plenty of ROCKRASH |
...just put rims and tires on sans sensors.:clap:
...$40.00 a piece for a 'dummy light'.:mad: $200.00 w/ spare.:eek2: not. ...set the aev pro-cal ($150.00 w/free shipping) to 0 psi and we're good to go.:thumbsup: ...this is a 'federal law' by the way, but the shop i went to for assembly said as long as i had 'after market' rims he'd leave the sensors off.:beer: ...big brother their to guide you along safely in your life because you may be incapable of maintaining proper inflation in your tires.:bleh: |
Depending on what size tires you're running a programmer is still needed to recalibrate your speedometer for the new size. If you don't do this, your speedo will show you going slower than you really are, which could lead to some pricey tickets. I went with the AEV procal because all I needed was to disable TPMS and calibrate my speedo for the 37s. SuperChips will do this and more if you have the extra $$$ to spend.
just get the procal ... turn off the light adjust speedo etc...:thumbsup: i sold a truck before without tmps monitors without a problem.. i wouldnt worry about it.
Originally Posted by rripror
(Post 1688684)
Originally Posted by 0311sgt
(Post 1688654)
Originally Posted by Ryan L
(Post 1689220)
Oh noes! How did anyone survive before 2008? :crazyeyes:
we can all blame the idiots who drove 100 mph through the cali deserts with 5 psi in their tires and then filed suits against firestone and ford. |
