Vibration
I have slight vibration at highway speed. It seems like it is coming from the rear driveshaft once I shift into overdrive. I crawled under jeep today and grabbed the driveshaft, and it has some play in the splines. My question could this be the cause for the vibration?
Not sure, but I don't think so. Have you checked your PSI? Did you check your tires for any bubbles or missed nicks/slashes? Any mud stuck inside the rim? Are your tires balanced properly? Could be at highway speeds, the problem is amplified...
There are many possibilities, need a little more clarification...
Sorry for the short description. It's 07 rubi 4 door with 97,000 miles. Has a small BB, not sure the size, came on the jeep when I bought it. I don't believe it's the tires. Like I said it only does it on flat road when ur in overdrive. If u accelerate it goes away or if u let off. The reason I believe it's the splines in the driveshaft, had a cherokee that felt the same way when the splines got play in them. I was wondering if JK had the same issue.
