Want to lift it
I am running a 2" suspension lift with new shocks and 305x70x16 MTR's (33") with American Racing 16x8 rims with 4.5" of BS.
The tires rubbed hard on the swaybar before the rim change and hit the inside fender and dam without the lift at full flex.
The ride is better with the lift and the 4.10 gears handle the 33's just fine with an automatic.
I like the look and functionality of the combo so far.
Here is the picture link
http://my.project-jk.com/showphoto.php?photo=55
-E
The more I talk to the wife about it, we should just lift it as well and go with the 33's , I think that would look and perform well for what we are looking to do. If I go with the 3.5 sky jacker, what 33 inch tire and wheel combo should I go with and what BS would I need? Thanks again
The more I talk to the wife about it, we should just lift it as well and go with the 33"s , I think that would look and perform well for what we are looking to do. If I go with the 3.5 sky jacker, what 33 inch tire and wheel combo should I go with and what BS would I need? Thanks again
Just my humble opinion, of course!
Here's a grab from INLO's gallery of 35"s on a 3" lift:
The first number, 255, is the width of the tread in millimeters (255mm is 10 inches). This is also called section width.
The second number, 85, is the aspect ratio. This is a percentage of how high the sidewall is compared to the tread width. So in this case, the sidewall is 85% of the tread width (217mm or 8.5 inches)
The third number, 16, is the diameter of the rim this tire is designed to fit (in inches, which is crazy since it's supposed to be a metric tire size).
To convert a metric tire size to a light truck tire size, you need to do a little math:
Take the first number and multiply by the second number divided by 100. This gives you the height of one sidewall. Divide by 25.4 to convert to inches. Multiply by 2 to get the height of both sidewalls. Now add the diameter of the wheel it will ride on to get the total diameter.
So, you get 8.5 + 16 + 8.5 = 33 inches in diameter.
The width of the tire is simply the first number divided by 25.4 to convert to inches:
255 / 25.4 = 10
The R16 part is the same for both. So a 255/85R16 is the same as a 33x10R16.
If you want a tire that is wider, you have to make sure you pick a new aspect ratio to keep the overall diameter the same.
Some 33" tires for a 16" wheel would be:
255/85R16 = 33x10R16
285/75R16 = 33x11R16
305/70R16 = 33x12R16
Notice how the aspect ratio decreases as the section width increases in order to maintain the same overall diameter.
-E
Thanks Jake, now I understand a little better. I looked at a black lifted unlimited that posted he has 315 70r16. That would be a 12 inch wide tire, correct? but sorry if I am an idiot but is 315 still a 33 or is that a 35?
that is a 33.4" tire...there is a good page that measures tire size and compairs different sizes for you http://www.miata.net/garage/tirecalc.html
I just order a teraflex 3" and 33's i hope and think that it will look good 35" look great but still a bit big for my taste i think...i have gone back and forth also...but i do alot of highway durring the week and i think the 33" is a better choice...i'm going to get the cooper stt, i have heard really good things about them
3" might be a little much for 33's even. My 3" Teraflex kit netted me 4" at the front flare and 3" at the rear. I had been considering the 2.5" kit with 33's before being persuaded to go bigger.
Thanks guy's for all the replies this is a great site. I think I will go with the 33's and the 2.5 inch lift, but that may change 25 more times before the night is thru. I have been looking at many sites for sales on wheels and tires plus lifts, any suggestions there? Thanks again, I really appreciate all the help.
