What to do for 33's
Old Nov 2, 2010 | 07:15 PM
  #21
cppower's Avatar
With Stock wheels, the minimum that you would need to run 285/70/R17 is 2 washers added to each steering stop, takes 5 mins.
  #22
sbcracer's Avatar
Originally Posted by Bobby D.
I have been looking for pics of someone with this setup. Can anyone tell me if there is any difference in the height of the black "x" that is pictured two posts up and a 2010 Sahara JKU? I want to get the largest tire possible that won't rub with the stock wheels and no spacer or lift.
THANKS!
Bobby
you need to climb under your jeep and look at the tag on your stock springs front and rear, different springs for different packages. springs numbers for front were like 13-19 the higher the number usually the stiffer and sometimes higher lift, i think mine were 18's up front and 59' in the rear. search on here for a post on stock spring numbers, also remember i have stock bumpers and no winch,
Old Nov 3, 2010 | 12:22 PM
  #23
Tgoods 09 X's Avatar
Heres a couple pics. Click image for larger version
ID:	99948Click image for larger version
ID:	99949Click image for larger version
ID:	99950Click image for larger version
There was no rub at all with the rear fully flexed. Im running 285/70R17 BFG T/A KO's
Old Nov 3, 2010 | 12:42 PM
  #24
RubiKing's Avatar
Save yourself the trouble and get 35"s. I wish I had.
Old Nov 3, 2010 | 12:52 PM
  #25
I would love to. But they're more expensive and I'd have to buy a lift also...
Old Nov 3, 2010 | 03:37 PM
  #26
DB Jeep's Avatar
285/70/17 mickey mtz. 4.5'' backspacing no rubbing.
ID:	99970Click image for larger version
Old Nov 3, 2010 | 04:07 PM
  #27
dmhines's Avatar
I assume when all you guys say "no rubbing" .. you mean on the street. Your gonna rub off road ... especially if you disconnect. If you plan on going offroad you'll probably need to trim your fenders.
Old Nov 3, 2010 | 04:15 PM
  #28
When I say no rubbing I mean no rubbing.. Disconnected the fronts are still good and with the rear fully flexed as well i have like half an inch to play with. Its close but no rubbing.
Old Nov 3, 2010 | 07:04 PM
  #29
Red-Dirt's Avatar
yeah, i mean on the streets. I dont know if they will rub if i trim my fenders, but i plan on changing out the fenders to something better with more clearance anyways.
Old Nov 4, 2010 | 04:01 AM
  #30
bpic0518's Avatar
Default To add to the mix...
I have 2007 Rubicon with factory installed 2.5 lift (no spacers)...ordering today Cooper Discoverer STT's 295/70R17...With the lift will I get any rubbing?? Also, will I be ok on stock rim...
