what jack points do you guys recommend?
Old Mar 19, 2014 | 05:03 PM
AXIS's Avatar
Default what jack points do you guys recommend?
So I found myself questioning where i should be jacking up my jku safely when installing my ball joints, tie rod and drag link.
Im looking to install a lift kit myself in the next week or two so I decided id try and get some advice as to where I should be jacking from to get the best clearances and to do it safely without damage.
Old Mar 19, 2014 | 05:09 PM
bbrown626's Avatar
Put some stands under the axle.
Old Mar 19, 2014 | 05:13 PM
Billbikes's Avatar
Axle works for your front end work, but you'll need to put the stands under the frame for lift install.
Old Mar 19, 2014 | 05:14 PM
karls's Avatar
Under the frame, right by the control arm mounts for your lift. Under the axle tubes is acceptable for your axle work (as described in the FSM)
