JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Modified JK Tech (https://www.jk-forum.com/forums/modified-jk-tech-2/)
-   -   What needs to be done for 35's? (https://www.jk-forum.com/forums/modified-jk-tech-2/what-needs-done-35s-184173/)
jbry311 Jun 28, 2011 09:49 AM
Thinking of putting 35's on, but have a few questions. Will a 2.5 coil lift be sufficient enough? Also my jeep came with 4.10's so re-gearing shouldn't be necessary, right? Are there any additional modifications that need to be done? I was thinking 33's, but 35's look even better. Thanks!
IcyFridge Jun 28, 2011 09:55 AM
You should be good to go. Might need flat flares for extreme flex.
A procal would be nice to set tire size.
Merlin4979 Jun 28, 2011 09:57 AM
You should be good with what you have. You might also need wheel spacers if you keep your stock wheels.
Other than that - go get those new tires ASAP! :beer::thumbsup:
dillUSMC Jun 28, 2011 10:00 AM
TF 2.5" coil lift with shock adapters and 35" duratracs, you'll be A ok :thumbsup:
http://i220.photobucket.com/albums/d...lonfly/014.jpg
jbry311 Jun 28, 2011 10:12 AM
Awesome. Thanks for the replies!
dillUSMC Jun 28, 2011 10:22 AM
BUT it also makes u think, how could u fit 37's :brows:
ChopN Jun 28, 2011 10:50 AM
I have a 4.10 manual and it does just fine. I feel no immediate need to regear but in the future I will. 6th gear is the only time I really notice lag. And I'm cruising on a flat freeway by then so it doesn't matter.
HG07JKRubi Jun 28, 2011 10:59 AM
you may also want to consider front axle C-gussets and a rear tire carrier for that new heavy spare so you don't damage your tailgate.
dillUSMC Jun 28, 2011 11:27 AM
X2 on the C-gussets, thats the next mod im savin up for after i put on my 35's, its always good to overbuild that way nuthing breaks, with that said you should look at C-gussets and EVO magnum sleeves :thumbsup:
jbry311 Jun 28, 2011 02:45 PM
School me on c-gussets.
© 2026 MH Sub I, LLC dba Internet Brands
