What size liftkit should i get ?
Hey guys wondering what size lift i should get for my jeep which had 32 cooper all terrains ! What size lift would not make them look to small but also provide cleareance? So help me out ! Thanks
I ran a 2.5" BB with 32s before jumping up to 35s. The 32s did look a little small but it wasn't horrible looking. A leveling kit would work great for you if you're not looking at running bigger tires than 32s
I don't think you want anything more then 2 inches. 32" with 1.5-2" looks ok and gives plenty of clearance.
top one has 2" and 32" and bottom is 1.5" and 32"
I plan to run bigger tires in the future so in ur opinion should i get the lift ? Or na ?
You don't NEED a lift to clear bigger tires. You can run 37s at stock height, all it takes is a little bit more planning and a lot more trimming.
You need to figure out why you're wanting to lift. Is it for looks? Belly clearance? Bigger tires?
A jeep with a 4" lift and 37s isn't necessary going to out perform a jeep with 2.5" lift and 37s.
Former Vendor
Like said before, you need to figure out what you want to do with the vehicle and what size tires you would want to run in the future. Rock Krawler recently released a line of 1.5" kits that you might take some interest in. If you need any help feel free to shoot us a pm. We can give you a great deal on parts for whichever route you decide to go.
You don't need a lift to run these tires. Stock suspension will give you the right space to run these no problem(rubbing). If your looking for a better look with 32s try getting a leveling kit.
Good luck. Jeep on
Good luck. Jeep on
