having trouble trying to find a kit that will bolt up to the Dina track axle. I would like to find a hi mount kit. the bottom mount beats up the stabilizer and leaking oil do to the tube rubbing against the bracket. the axle tube is 3 inch diameter and the stock is 2.5 inch. dual stabilizer kit won't work due to the axle tube being 3 inch diameter.
bump bump bump help
I just installed a fox 2.0 on dynatrac pro rock 44 with a poly performance tie rod. I had to weld on mounts to the dynatrac and used the stock mount on the poly tie rod. It moved the ss on top of the tie rod.
thanks. did you fabricate the mount for the axle or did you buy 1. if you bought 1 what did you buy.
