what tire pressure are you running on the Highway with bigger tires?
Sponsoring Vendor
Quadratec Rep
Quadratec Rep
When running larger tires I was wondering if everyone is still running your vehicles recommended PSI, more PSI, or less PSI?? Also for comparison could you give your Jeep Model, Tire Size & PSI.
You may not like this answer too much, but its more personal preference. I am running 33s with 30lbs of pressure. You should run at least 25 for the street and no more than the tire recommendation which is 50lbs for alot of the 33s and 35s. The less pressure the softer ride, the more pressure harder ride but better mpg. Just my 2 cents.
I am running 32psi in my 35s, but I'm thinking of raising it a little once all the ice melts off the streets. Right now the tires feel a little squirmy on dry pavement.
-E
-E
Right now I am running 30 PSI in my 35's. They seem to have a good contact patch at that pressure. When I get some mileage on them I will adjust the pressure based on how they are wearing. A JK is lighter than most of these tires max load rating so you don't need to run alot of pressure in them....my 2 cents.
The best way to determine what tire pressure you should run involves a flat area with a smooth surface, like a parking lot, and a stick of chalk. Air up the tires to about 40 or so to start with. Take your chalk and leave a THICK white line across the width of your tire. Now drive back and forth for a little bit. Get out and look at the mark you made. Keep lowering your tire pressure untill it wears off evenly across the mark at the same time. Then go 1 psi lower, because you started out on the high side. You could start out low too, but it's a lot easier to let air out, than put it in when your in the middle of a parking lot.
JK-Forum Founder
There's a write-up in the latest JP magazine (April 2007) on this.
They show the chaulk routine also.
I'm running BFG MT 285/70-17's. I was originally running the stock Rubicon pressure, which is 37psi. With this pressure in the new tires my teeth were getting rattled out. I then noticed the sidewalls on the new tires were much firmer (higher rated tire), so I did the chaulk test. I was wayyyy to high in pressure.
I'm down to 27psi right now and the chaulk line is just about right, it still actually shows me as being a little too high in psi, but I'm a little leary about going any lower than 27psi. The ride sure is nice again though, and the Jeep seems to wander way less.
husky~
husky~
