wheel offset and backspacing?
Old May 4, 2012 | 12:50 PM
darlep's Avatar
Default wheel offset and backspacing?
I found rims I want and they do fit....how will these specs affect fitment?
Offset: 10mm Backspacing: 5.15
Looking for someone to say ok so I can pull the trigger...LOL!
Old May 4, 2012 | 12:56 PM
snopro269's Avatar
I try to go with 4.5 or less Backspacing just so I don't have to go with wheel spacers
How wide of tires are you going to run
If you get to 12.5 or wider tires you'll have to get spacers unless you get 4.5 Backspacing
Old May 4, 2012 | 01:45 PM
ricksjeep10's Avatar
The rims will fit fine if your staying with the original tires. The stock wheels have 6.25" of backspacing so the new wheels will stick out a little further. If your planning on moving up to 35" tires in the future, you will need wheels with a backspacing of 4.5" or less.
Old May 4, 2012 | 02:01 PM
snopro269's Avatar
Thus what I said of tire width!!!
Old May 4, 2012 | 02:55 PM
darlep's Avatar
How far will they stick out and yes I will be using stock tires??? I don't want them to stick out too far...
Old May 4, 2012 | 03:36 PM
themoneyshot's Avatar
should be fine. so what are the rims?
Old May 4, 2012 | 03:37 PM
snopro269's Avatar
Well there you go, if you don't intend on going bigger tires your set. Do a little math current offset minus the new offset
Kinda a half ass way of doing it and not exact but the difference is that much or less wider
1/4 inch
Old May 4, 2012 | 06:12 PM
Wandell's Avatar
Loved
How wide are the wheel?
Old May 5, 2012 | 04:44 PM
darlep's Avatar
8.5 wide
Ultra Crusher Black Painted
Old May 5, 2012 | 04:56 PM
matprovo's Avatar
I'm pretty sure the offset doesn't matter. It's the back spacing you have to be concerned with. Back spacing and offset are different.
