wheel spacers
Old May 7, 2010 | 11:56 AM
Default wheel spacers
So I ordered a BDS suspension lift and it says that I need 4.5" backspacing on my wheels so I ordered new wheels and tires to go with it. My wheels are on backorder so I was wondering if I absolutely need wheel spacers to to run the stock wheels for only a week or two or would it not work at all?? thanks fellas
Old May 7, 2010 | 12:34 PM
JKRINGO's Avatar
Thought I saw somewhere that stock rims had 6"+ backspace. If thats true you would risk damage to your new set up.
Old May 7, 2010 | 12:48 PM
spinlock's Avatar
The 35x12.5 tires will have interference problems on stock rims without spacers.
Check the Modified FAQ for the specs.
Old May 7, 2010 | 12:58 PM
FNS2DLFT's Avatar
I am running the BDS lift with stock rims and 35 inch tires, you will need the spacers. I think mine are 1-1/4 and when I turn all the way to the stops my tires rub slightly on the rear of the tires.
When I get new tires I will also be getting new wheels that are back spaced so I can take off the spacers.
Old May 7, 2010 | 01:01 PM
stlfan06's Avatar
X2 But I don't think he's planning on mounting the new 35's to his stock wheels and then remounting them to his new wheeels. I assume the OP is asking if he can run his stock wheels+tires until his new ones arrive.
In that case, you should be fine for a week or two. I'm currently running the TF 2.5 w/o spacers and it does rub off road, but as a temporary thing, it shouldn't be a problem.
Old May 7, 2010 | 01:23 PM
Thanks guys but I would be running STOCK RIMS AND TIRES. NOT 35x12.5's.
Old May 7, 2010 | 05:30 PM
Anyone know if the stock rims and tires will be a problem???
Old May 7, 2010 | 07:46 PM
Phoenix07013's Avatar
my understanding is that you would have clearance issues with the extended sway bar ends, but im not sure
