Where to connect to a dash light circuit
https://www.jk-forum.com/forums/jk-e...lights-311176/
If what you meant instead was to get power to the radio that is switched with the ignition, then this is the easiest solution ...
https://www.quadratec.com/products/96080_9801.htm
BTW, since you haven't filled out your profile letting us know what you own and how it's been modified, all the above and referenced info may not apply at all to whatever you're modifying.
Zx14 (05-08-2021)
Over on the drivers side, under the kick panel, where the plug from your door plugs in. Look in that pack of wires for the orange wire with the grey stripe, if I remember right.
