Who has the most complete 2" lift under $700 ?
I don't know anything about lifts so I'll get that out of the way first.
I hear great things about the OME 2" lift but when I look at others that offer more stuff like sway bars, trac bar adjustment, etc. I get confused to what I should get in a lift kit package.
What do I really need to look for in a coil spring kit ? Dont want a BB kit as I don't like the fact coil spring spacers are against the law in Michigan.
Thanks - 2008 Sahara 4-door all stock for now.
http://northridge4x4.com/proddetail.php?prod=TF-1251000
How much 'actual' lift height do you want? OME has quite a few different coils for the JK, and as far as I know, none of them actually give 2". The HD's will put your 4door up in the 3-3.5" range, the +40s will get you somewhere in the 4-4.5" range. Sound good? The lights and mediums will be somewhere under 3, but they sag, so may not be the best choice if you plan on adding some weight.
Open the FAQ's stickied to the top of this modified area and read the suspension section for some info on suggested components for various lift heights. Then do a little research and figure out what each of the components does. And then...start looking at specific lifts so you have some kind of a clue which components 'you' will want.
My opinion: Over 3", get longer links, axle centering, some form of caster correction, bump stops, brake line brackets, etc. Just depends on the lift height you end up at and how incomplete of a lift you can live with...
Thanks, this is a DD for now as its my wifes rig for a while. Not planning on adding anything but a lift and larger tires.
Like I said no experience with lift so dont understand the trac bar relo bracket, drop pitman arm, transfer case lowering, etc. Is all of this necessary to do with a 2 or 2.5 inch lift ?
I run a 3.5 Rusty's lift and really like it for under $700, but in your case I would look at the Teraflex 2.5 BB....get some good shocks and call it done. Install is straight forward and Teraflex has great customer service.
$0 used OEM Rubi Unlimited rear springs
$80 1/2" TF rear coil spacer from Northridge
$80 new OEM #18 front springs
$50 used 1" TF front coil spacers
$220 used 1000 miles OME Nitro shocks
That stuff netted me +2.25" in front, 1.25" in the rear. I have JKS QD's, too, and some sort of longer swaybar links needs to be added to the RC kit as well.
