Who have the Performance Accessories B.L.?
Old Mar 2, 2010 | 07:39 AM
MasterG's Avatar
You're not alone ! Take a look a this redrockin7's thread..
https://www.jk-forum.com/forums/modified-jk-tech-2/emergency-body-lift-question-progress-need-finish-120942/
Now let us know if you can arrange something with the rep here..
Everybody seem to have to drill a bigger hole for the 2 rear pucks...
Old Mar 2, 2010 | 07:48 AM
redrockin7's Avatar
Everyone with an 08, I believe it is... The directions clearly state that some model years use all the same size bolts, I even had two left over (obviously). But for mine, I needed to use the slightly larger (2mm larger maybe?) ones in the rear and definitely didn't slide through the pucks.
They threaded through when I put it in the vice with a wrench ratchet, but were not easy to get through once on the rig. Drilling it out is an easy option as its relatively soft compound they are made of, but I just don't think you should need to do that.
I can't imagine that if you supplied 2 pucks with larger holes, but then the person had an 07 that used the smaller bolts in rear, that it would make much/if any difference. The bolt will still be through the puck and torque to 80ft lb...
Old Mar 2, 2010 | 07:52 AM
MasterG's Avatar
Do you know if the 2010 have the same bolt size than a 08 ?
Or Somebody else ?
Old Jun 24, 2010 | 04:13 PM
ClaytonTheAggie's Avatar
Or Somebody else ?
I just installed this kit on my 2009. It is set up just like the 2008-- the rear bolts are the larger bolts. 2010 ahould be the same. You will cut your install time in half if you could find the washers somewhere like an auto parts store rather than re-use the old ones. Took me FOREVER to get the old washers off. Also, don't forget which washers came from the two rear bolts. Those washers will fit on any bolt, but put them on another bolt and you won't have one to fit the rear bolts...don't ask how I know.
Now, ALL the pucks are drilled out to the larger bolt sizes. 10 pucks, all identical.
Old Jun 24, 2010 | 04:26 PM
MasterG's Avatar
IMO, thats the way they should be produced..
thanks for the info bud !
Old Jun 24, 2010 | 06:10 PM
they must have fixed it. I just installed mine and I had no problems at all.
Old Jun 24, 2010 | 06:29 PM
RLW007's Avatar
It looks like maybe PA has solved the puck/hole issue. My new PA 1" BL also has too larger bolts for the rear, but all puck holes are large enough for the larger bolt. I will install it this weekend on a 2010 unlimited.
Old Jun 24, 2010 | 06:37 PM
Darth JK's Avatar
I installed mine about 6 months ago and had no problems! 2 of my pucks had larger holes in them! Glad I checked befor putting them on!
Old Jun 25, 2010 | 12:51 PM
MasterG's Avatar
Nice to know.. they seem to have fixed this prob, great ! They made some good BL..
