Why do larger tires effect performance/mpg??
I'd have to say mainly the added weight. The more weight you put on a vehicle, no matter what kind of weight that is, will bring down performance. Why do you think there is so much plastic on todays vehicles?
^^^^^ what he said. weight, friction, drag, all that good stuff. same with driving around with just a driver vs full of passengers, gear, full gas tank, etc... the more you add, the more gas you use.
AK4Dave types faster than me.
Weight does play a factor, but so does the change in engine RPM at driving speed. Todays engines are engineered to be their most fuel efficient at a certain RPM range. When you increase your tire size, you lower the RPMs required for the same speed, and end up operating your engine outside of its designed peak fuel performance range.
