Why is ESP activating after new lift installed?
OK group, I searched the forum, but I didn't find a specific answer or root cause to this problem.
I installed my new 3" FT Ultimate lift and 35"MTZ's last week and now when I am completing long sweeping turns (Freeway ON-Offramps) my ESP engages as if I am losing traction. This is not the case, I am simply driving 30-40mph on dry pavement in 2WD.
Have any of you experienced the same issue and what have you done to eliminate this problem?
BURNDOG
BURNDOG
very common problem, very simple fix.
The procedure for recentering your steering wheel is here:
Basic Do-it-Yourself Jeep JK Wrangler Front End Alignment
Also, you may want to take it to the dealer and have them reflash the computer for the lift using their nifty StarScan tool. There's a TSB out about it.
Edit: I had it done when I put on a 3/2.5" BB and it still came on periodically, but after I took it to Moab it hasn't been on once since.
Burndog. I experienced this exact same problem. An alignment alone isn't going to solve it. Reprogramming the ECU with my Hypertech didn't take care of it either. I had to get front adjustable upper control arms plus an alignment in order to correct the problem. When you lifted the vehicle, it "rolled" the axle forward. Putting the adjustable uppers on will allow you to "roll" them back. I got mine through Dave at Northridge. Hope this takes care of the problem for you. I still get a minor stutter around a certain corner near my house but not anymore on the on and off ramps.
