Wider stance
When i buy new wheels, how can i get the tires to stick out a little bit wider? I am going to be running 35's, but also dont want to rub either. Is that possible with a 3-4" lift? Ive been looking at wheels and see all different sizes on backspacing and not sure what that means. Oh, and i already have spidertrax wheel spacers, but if i dont need them that would be good. Any help will be nice.
Think about the point of where the face of your wheel hub that mounts to your axle hub is positioned in the wheel.
Further towards the outside of the wheel is like a stock jk wheel and tends to have rubbing issues with larger tires.
When the mounting surface of the wheel is positioned more towards the inner part of the wheel that is better for larger tires....less back spacing. It can add more stress to your axles, so i wouldn't recommend say a wheel with 4.5 backs pacing and your ws.
Originally Posted by CF2010
My wheels have a 4.5" backspace, my tires are approx 10.5" wide and the tires extend past the flares by about 1.5".
I have 17"x9" wheels with 3.5" backspace, and they stick out quite a bit. I haven't measure it, but the closest pic I have is actually of my slider. You can see that they definitely stick out (and they do) with the 35/12.50 Nitto Mud Grapplers.
