winch
I have never had or used a winch before. Can someone tell me why they don't get destroyed by mud and constantly being wet (rain and mud puddles)? Is there special care needed to make them last?
buy a good name brand like warn or ramsey and you should not have much issue. i had a m8000 warn on several jeeps for 14 years before i finally sold it and bought a new one. it was still working fine and all i did was wash it when i washed the jeep. went through two or three cables but no winch repair.
Just go to the mfg's website and read...
Here is what Warn says:
This winch not only looks great, but sheds the elements like no other winch on the market: seals at the key points give extreme-duty water resistance.
They are tough, can take a beating, I suggest buying a reputable winch....I have always ran Warn, and they haven't let me down.....This mod (winch) usually can pay for itself the first time you use it
Mine has payed for itself many times over
During the winter, I usually cover mine to keep the salt and flying rocks from plowtrucks off it etc...During the summer I tend to keep the cover off, to prevent the winch from sweating (in certain evironments moisture will remain under the cover, which isn't good
Mine has payed for itself many times overDuring the winter, I usually cover mine to keep the salt and flying rocks from plowtrucks off it etc...During the summer I tend to keep the cover off, to prevent the winch from sweating (in certain evironments moisture will remain under the cover, which isn't good
I've got a superwinch EPI 9.0s and deep water has never bothered it. It did however quit working when I had it submerged in really soupy mud trying to use it. The brushes got mud in between them and the housing they slide in and they quit making contact. I took the motor apart, cleaned it up and it works perfect again. The only winches that I've found that state the motors are sealed are the WARN Ultimate Performance Series winches. The cheapest of which is over $1000.
Originally Posted by mwebb
you get what u pay for
Lol I hear that all the time but with no explanation, if someone uses a winch a hand full of times a year (5 or 6) what makes a warn that much better? I know that in the long run they will last longer, but let's look at 5yrs or so? In 5 years time, using it a hand full of times a year, what can one expect from a smitty?
This thread has some good info. Be sure to follow the link in post 7 for a winch shoot-out. Not all-inclusive, just good reading.
https://www.jk-forum.com/forums/show...ighlight=winch
A quote from that review:
Be it effective marketing, brand recognition, reputation, or simply propaganda, all testers involved had an expectation that the sun will rise in the East and the Warn will accomplish the pull. While the other winches were being watched closely to see if they would finish, the Warn’s ability to finish a pull was never doubted. In fact, it only received an occasional glance to see when it was done. This peace of mind alone may be worth the premium price to some readers.
