winch fairleads help!
hello to all my fellow jeepers!
i have a bit of a problem. i have a rugged ridge 10500 winch with the synthetic line and the daystar rubber fairleads exchanged with the rugged ridge fairlead. so i got to use my awesome winch out helping some other fellow people and yes myself getting out of a sticky situation. its the first time i really got to use my new winch well when i was winching out the line starting tearing through my fairleads:thinking: there brand new is there a flaw with it or something has anyone else experienced this or am i doing something wrong. im about to get ahold of the daystar people to see if i can get this replaced . could the cold have something to do with this its around 8 to 35 degrees right now? well any help or advise would be awesome and thank you in advance.:beer: |
Originally Posted by SIDsjeep
(Post 2088114)
i have a bit of a problem. i have a rugged ridge 10500 winch with the synthetic line and the daystar rubber fairleads exchanged with the rugged ridge fairlead. so i got to use my awesome winch out helping some other fellow people and yes myself getting out of a sticky situation. its the first time i really got to use my new winch well when i was winching out the line starting tearing through my fairleads:thinking: there brand new is there a flaw with it or something has anyone else experienced this or am i doing something wrong. im about to get ahold of the daystar people to see if i can get this replaced . could the cold have something to do with this its around 8 to 35 degrees right now? well any help or advise would be awesome and thank you in advance.:beer: A traditional fairlead can mangle your expensive synthetic line. |
Originally Posted by Torrin
(Post 2088138)
Ummm, I do not know what you are using, but I believe you should be using what is called a hawse fairlead for synthetic line, like these.
A traditional fairlead can mangle your expensive synthetic line. If you want to use a traditional fairlead with Synthetic you can change out the metal rollers for plastic and they are perfect. |
I don't know what hew means by rubber fairlead? I have only seen metal ones and it sounds like he has two. One from Daystar and one from RR? How can you have two?:thinking:
I think by the sounds of his post he has the rubber or plastic rollers in his RR fairlead:beer:
I guess that is why I bought the EVO Hawse for mine.
Originally Posted by john smack
(Post 2088235)
https://www.jk-forum.com/forums/atta...hmentid=107422 heres a pic of my jeep with them hope this helps |
the line was basically cutting right into it like butter idk if its spinning right or what but if anyone out there has experienced this or knows what i need to do to fix it or a trick would be awesome. i really would prefer to not use the hause type fairlead seen how i have this one.
Viking has some rollers made of Delrin instead of the Polyurethane used by DayStar.
Originally Posted by ARinmyJK
(Post 2088484)
| All times are GMT -8. The time now is 05:20 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
