Winches
Old Jan 14, 2011 | 10:28 PM
phil0352's Avatar
Is there any one arb compressor that I should look at?
Old Jan 14, 2011 | 10:38 PM
nthinuf's Avatar
Depends on what you want it for. The smaller one (cksa12) is for the lockers only. The larger one (ckma12) is for both lockers and tire inflation. There is also a portable (ckmp12), and a 24v version (ckma24).
More than likely, you will want the CKMA12
When you go to On Board Air, click the 'On Board Air Systems' button, not the Air Compressors button. That is where the package is.
Old Jan 15, 2011 | 03:52 AM
phil0352's Avatar
I just got done looking at the recon winch. I like it but, will it work with the arb bull bar deluxe. According to arb the warn dp will fit. If that helps???
Old Jan 15, 2011 | 10:26 AM
mattonline's Avatar
Depends on how much you want to spend, right? I wanted the winch and the compressor separate for reliability reasons. I have never seen a compressor of any kind fare well when it's directly exposed to the elements - especially on the front bumper. At least the ARB is under the hood, although the heat generated under the hood certainly doesn't help the wear and tear of any mechanical device.
Old Jan 15, 2011 | 01:30 PM
sikjeep's Avatar
Viair compressors all the way
Old Jan 15, 2011 | 03:52 PM
snopro269's Avatar
Ok this is my question?! How long does it take to air up 35's with ARB and other air setups? According to Warn the power plant is pretty fast and runs tools. Also there are several places sell the 9500 power plant shipped for $1300.00
Old Jan 15, 2011 | 04:02 PM
NeverStock's Avatar
I have the arb... Takes me about 90 seconds to air up a single 35" tire from 10 psi to 30 psi... Would highly recommend the arb on board air system... I love mine!!!
Old Jan 15, 2011 | 04:30 PM
Fenrir's Avatar
I like all my "components" to be separate.
I never even bought those TV/DVD player combos. Glad I didn't too since Blu-Ray came out! Also if one breaks, then you don't have either? (Dunno if that is true for the Dual Power Plant Winch).
Old Jan 15, 2011 | 04:48 PM
nthinuf's Avatar
From their websites...
ARB
2.65cfm @ 0psi
2.18cfm @ 29psi
Warn
12cfm @ 0psi
5cfm @ 90psi
Great numbers on the Warn, but you also need to note how much bigger it is, and that it has a built-in air tank also. Can't really compare them on equal terms.
Old Jan 15, 2011 | 06:17 PM
snopro269's Avatar
Yeah I always have people with me and no air so I'm thinking the warn is my best route. Plus I don't have anything else to run on air. My prorock 44 is electro!!
