JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Modified JK Tech (https://www.jk-forum.com/forums/modified-jk-tech-2/)
-   -   Winches (https://www.jk-forum.com/forums/modified-jk-tech-2/winches-194827/)
matt852 Sep 7, 2011 09:27 PM
Winches
What's the deal with the 8000, 9500, 10,000 and 12,000 pound winches? Which one do I really need for the jeep?
HCSTHS43 Sep 7, 2011 10:03 PM
I'm curious about this too. I have a 8000lb winch from a previous rig that I will be installing as soon as my bumper comes in next week. I have been wondering if this will have enough power to pull my 4 door if I was stuck in some deep mud.
dogsonparade Sep 7, 2011 10:25 PM
Is this a joke?! Just kidding.
Short answer, any of those listed will do.
I have a two door with an 8000 and some snatch blocks (doubles the pulling capacity). A few people with JKU's have 8k's also. Using a snatch slows your line speed but if it gets you out that's not really an issue is it? Getting a bigger winch, you'd be able to pull a lot more (naturally) while also drawing less power from your battery, so I've read here in the forum. If you don't do hardcore wheeling through treacherous swamp or pulling you up a jungle mountain is line speed or power draw much of an issue? Probably not. 8k and a snatch block or two should do just fine. If you want piece of mind go with a 9.5k or 10k.
dinojeep Sep 7, 2011 10:36 PM
yup, 8000 should be just fine. I got a 9500 powerplant cuz I play with pick ups that are a lot heavier than me. But 8000 should be plenty. Like stated the use of a snatch block is a good idea for heavy pulls or pulls that don't allow a lot of line usage.
Bull Sep 9, 2011 09:59 AM
Rule of thumb is to have a winch rated at 1.5 times your max loaded weight.
mstrofpuppets Sep 9, 2011 02:28 PM
I use a warn 9,000lb on my 4dr got it from a buddy cheap. Have used it to pull out 3/4 ton trucks stuck in snow. It works very well. I don't think you need a high priced winch for weekend wheeling but then again you might. One thing to look at is line speed. Hope some of this helps.
matt852 Sep 9, 2011 04:04 PM
Oh yeah line speed too, do you want a relatively fast one or a slower one or one in between?
© 2026 MH Sub I, LLC dba Internet Brands
