Wow jeep dealer theu don't really know about jeep..
Old Jan 25, 2013 | 10:23 AM
janicelove's Avatar
Default Wow jeep dealer theu don't really know about jeep..
I left my jeep to dealer to fix something.. And when i get back my jeep, they adjust my tire as 45 psi...
Old Jan 25, 2013 | 10:27 AM
carolinajk's Avatar
youll find some good wrenches and knowledgable techs at some dealerships , you will also find guys just starting out . and guess what they do...... services .next time tell them what you want your tires adjusted to or better yet , trust no one and do it yourself
Old Jan 25, 2013 | 10:52 AM
mistasparkl's Avatar
IME I've found pretty much all dealers and tire shops over-inflate the tires, I've always had to go back and let air back out whenever I get tires mounted.
Old Jan 25, 2013 | 11:22 AM
TURTLECON's Avatar
^^x2
They always inflate to manufacturer specs. Must be a legal/liability thing.
Old Jan 25, 2013 | 11:27 AM
jkjouster's Avatar
45 is not manufacturing specs
Old Jan 25, 2013 | 11:37 AM
Four Low's Avatar
What does the tag on the door jamb list for PSI? They might have set it to max on sidewall.
Old Jan 25, 2013 | 11:40 AM
carolinajk's Avatar
thats more like it , the stock tires are 30 something .
Old Jan 25, 2013 | 11:52 AM
jk_sea's Avatar
Anytime someone touches my car other than me, it's cause for my own safety-check. Is there oil in the motor? Are the wheels actually bolted on? Did they mess with my tire pressure?
Old Jan 25, 2013 | 12:22 PM
dis_dis's Avatar
Thats a cheap and inexpensive way to find out about your dealership. I would double check the repairs they did to your Jep and steer clear of them in the future
Old Jan 25, 2013 | 12:28 PM
Mschneid's Avatar
Yep, I went in for a belt and locked up idler pulley, after they fixed it they filled my washer fluid (thanks fellas) but never checked/added antifreeze it was a gallon low and I had to use my $31/gallon Mopar antifreeze.
They also didn't hook up the cold air intake right either, the tube to the box was folded under so it was letting in unfiltered air.
It's a shame when you go to the "best of the best" and you get work that any corner garage can do. Thankfully it was under warranty and I didn't pay for a half @ss job.
