Sponsored by:
Sponsored by:
Your Opinion on these C Gusset Welds - PICs Provided
Old 10-08-2017, 05:57 PM
YukonBlu's Avatar
Default Your Opinion on these C Gusset Welds - PICs Provided
Hey guys, so i went and got my gears installed and while i was at it i had them weld on C Gussets to my inner Cs. I am a pretty picky person when it comes to my jeep, well really picky. In the pics i provided you see the welds on the inner Cs. I have seen good welds and also have looked at other jobs where the inner Cs Gussets were welded on and looked really good. But to me the welds on my Cs don't look so good. I need some opinions on this, and what should i do about it. Some of the welds look
ok, and some of them look terrible to me. Thanks
WELD UPDATE... SEE MY LAST POST WITH NEW PICS!!
ID:	675343Click image for larger version
Name:	Weld2 - Copy.jpg
ID:	675344Click image for larger version
ID:	675345Click image for larger version
ID:	675346Click image for larger version
ID:	675347Click image for larger version
Old 10-09-2017, 02:31 AM
karls10jk's Avatar
Someone was inexperienced or in a hurry when they did it. You can grind the welds out and re-weld them if you'd like. With welding it's really more about penetration underneath and less about how pretty they are. Those welds look to be a cross between not enough heat and 'jumping'...almost like tack weld
Granted....It can be harder to do the overhead weld and you want to avoid putting too much heat up at the bj area but your welder should be competent in these areas.
Old 10-09-2017, 04:06 AM
T&ERun's Avatar
Yep, not enough heat or too fast on the wire speed. Cold welds with not a lot of penetration.
Old 10-09-2017, 08:27 AM
caryt's Avatar
Perfect example of someone who doesn't know how to weld...get your $ back.
Old 10-09-2017, 10:55 AM
YukonBlu's Avatar
So I talked to the shop and they said they would grind out the welds and redo them. Do you think I should redo everything? I'm not trying to damage my axle.
Old 10-09-2017, 12:18 PM
resharp001's Avatar
Received 1,824 Likes on 1,594 Posts
Man, what a PITA. I'd hate to be the person that has to grind all that and redo it. Sucks all the way around....for them and for you even having to deal with it.
I'd be on the fence myself for the same reason you're questioning it. They didn't do it right to begin with.....you want those same people grinding on the axle now and redoing it? It might not be perfect, but I wonder if it's still good enough to serve it's function, and maybe the angle should be some sort of refund instead.
Subscribed to see what others say.
Old 10-09-2017, 03:12 PM
karls10jk's Avatar
If the gussets are at the correct angle for bracing the C then I'd leave it be and find someone else to burn in over top of it. You won't burn up your seals by having your gusset work redone but it could toast your bj's.
I'm sure the shop would be professional about the work but if you're the guy who has to grind out the weld with avoid destroying the functionality of those brackets.....you'd be pissed and probably in a hurry to get the pain over with.
Old 10-10-2017, 04:11 AM
T&ERun's Avatar
Find a shop that can re-weld them but using tig. If you're good with a tig torch you can redo those using the existing filler, compared to adding more filler with mig. It will look much better and it would be stronger. If I were close to you I would do it for you.
Old 10-10-2017, 08:36 AM
YukonBlu's Avatar
Well the shop said they would fix it, so I guess I will let them try. Do you think I should have them fix all the welds?
Old 10-10-2017, 08:56 AM
rsbmg's Avatar
I would think if they didn't already screw up your ball joints the second go around on the welds will.
Quick Reply: Your Opinion on these C Gusset Welds - PICs Provided
