Your setup looks good. I was planning a TF 2.5 spring lift for my soon to come 2010 1/2 door. I also plan to run 35's on 15 inch wheels. I had d rated 16's on my 07 never again. I will look at the Zone lift.
I'm sure this is an old thread. But I've had my Zone 3" inch for about 6 months now. Don't use their rear track bar relocation bracket, when passenger rear tire goes into the wheel well, the shock smashes the brackets, and make it real ugly. Don't use their sway bar QD's either. Bad design, they have some goofy bracket, and even after welding mine to the axle it still wiggles and wobbles.
DO go with 35's, I have 33's and they look to small on there. My spings did sag (even though they promised they won't) about .5-.75 inch. It's not that bad though considering that they WERE over 3 inches when I installed them, so I would say it's actually sitting at a true 3 inch lift. I put in a 1 inch spacer to level the rake out, and it worked well. The lift does flex very well. The cam bolts, junk. I through on a set of adjustable lower control arms. I'm waiting on my Pro Rock 44 now, with that I'll re-gear the rear to match, order new rear adjustable track bar, and new QD.s and probaly rear lower control arms just because I've seen the stockers fold up like pretzels. Oh yeah, I did have to disable my ESP. Which I don't mind, I hated it anyhow. haha |
Nice
Awesome transformation!!!
A, I wanted to bring this back up,..Long term report. (20k on lift)
with the Zone 3" lift, I also ordered their sway bar QD's and front Track Bar. Well, first the sway bars come with a silly bracket that 'rest' on the axle. Well, that peice constantly moves, so we welded it, and they still move all over the place by bending and flexing. So, I am replacing those soon. The track bar,...wow. JUNK!!! I noticed today my steering was a bit 'loose'. The threads inside the track bar, seperated from the sleeve and now has about 3/4-1 inch of play! My steering is all over the place, and it gives me a scary "death wobble". So, I will be next daying some new JKS one's tomorrow. |
Originally Posted by deputydog
(Post 708257)
PS... don't buy the spare tire spacer or the third tail light ext kit, about $100 bucks, you don't need it whith these rims due to the backspacing.... about 3.75. Fits right on.
