ICON Complete Kits - Jeep JL 2.5" Lift
Former Vendor
ICON has logged over a thousand miles in the dirt pushing the JL to off-road extremes to identify limiting
factors in OE components.
ICON has developed products that remove these limits, and further extrapolate performance out of the Jeep JL.
The ICON 2.5” Lift Suspension System has been tweaked, tuned, and revised several times over the course of
testing in an effort to provide unparalleled ride quality and vehicle dynamics for everything from rock crawling to
high-speed desert running.
The ICON Vehicle Dynamics Stage 1 2.5" Suspension System for the 2018-UP Jeep Wrangler JL is designed
for the driver looking to drastically improve the performance and ride quality of their vehicle.
KEY FEATURES:
- 2.5" lift height
- Fits 35" tires (37" with optional extended bump stop spacer kit PN: 22029)
- 3" front, 2" rear increase in wheel travel
- Improves on and off-road ride quality over stock
- Dual rate coil springs with lifetime guarantee against sagging/breakage
- 2.0 Aluminum Series shocks with vehicle specific valving
- 100% bolt-on system makes for an easy install
- “ICON 1K” tested under rigorous off-road conditions to validate tune, performance, strength, and durability
- Recommended wheel and tire fitment is based on a JL Rubicon
- Advertised lift heights based on a stock, 4 door JL Rubicon
WHEEL & TIRE FITMENT INFO:
OEM Wheels & Tires: Yes
Aftermarket Wheels: 8.5 Wide, 4.75" Backspace
Aftermarket Tires: 35 x 12.50 (37 x 12.50 with optional extended bump stop spacer kit PN: 22029)
SYSTEM COMPONENTS:
22025 (QTY.1) | 18-UP JL 2.5" FRONT DUAL RATE COIL SPRING KIT
22026 (QTY.1) | 18-UP JL 2.5" REAR DUAL RATE COIL SPRING KIT
26523 (QTY.2) | 18-UP JL 2.5" FRONT 2.0 ALUMINUM SERIES SHOCK VS IR
26524 (QTY.2) | 18-UP JL 2.5" REAR 2.0 ALUMINUM SERIES SHOCK VS IR
OPTIONS:
22029 | 18-UP JL EXTENDED BUMP STOP SPACER KIT
For a Complete List of Kits - Click Here
*When ordering online, use promo code "JKForum" for added savings on most brands
