Originally Posted by lowendrider
(Post 4337746)
Looks great...JL takeoffs?
Originally Posted by carid
(Post 4337852)
Congrats on your purchase - you've made a great choice. Make sure to show us some more pictures, when you have a chance. What are your plans for this beauty?
Oh, and I have to fix this F#$%*(@D gas tank fill up issue. So far, the only complaint that I have, and it SUCKS to have barely squeeze the pump handle and spend 15 minutes of my life filling up one tank of gas. |
CNNX321AC, I think is the part number you're looking for. It's on eBay, Amazon, etc, and you'll usually pay $20-25 but it's worth it. There is a hose that lives just above that line and you'll be tempted to zip tie it super tight to your newly installed tube- don't. Loosely secure it because at the gas tank side is a super low quality plastic that likes to crack and produce P0456 codes.
(Post 4338406)
To be clear, my problem is not that the gas overflows at the end of a fill up. My problem is that gas will overflow from empty to full unless the nozzle lever is squeezed no more than the minimum needed to flow fuel from the pump. |
Okay, I replaced the filler hose assembly, and it helped slightly. Instead of taking 15 minutes to fill up it takes 12. I can pump fuel at a low setting but eventually it will back up and stop numerous times no matter how slow I pump. The main difference is that no fuel washes back out of the filler neck - so that is a positive. It appears that I really need to drop the tank to access the rollover valve and modify or remove it.
I'm curious how your rollover piece got messed up. Be careful with the lines on top of the fuel tank, the connections on the tank are a brittle plastic, particularly the smallest one that's towards the rear, it vents out towards the fuel input at the body. Just moving it a little more than it liked set off a Pxxxx code for a small evap leak. New tanks are $300+, even at junk yards.
There is a defect in the design or construction of the stopper valve which causes it to get lodged in the up/almost closed position. If you google, you will see it is a common problem from 2007-2012 or so. There is actually a lifetime warranty on 2007-2008 JK gas tanks for this reason. My understanding is that Jeep originally replaced the tanks (and sometimes more than once) to resolve the problem, but then later switched to replacing the filler hose and adding a valve inside that assembly. The "fix" is to remove the rollover valve, sand down the nibs on the side of the plunger body, and reassemble. I am not interested in going to all that trouble right now, and I will see how livable things are with what I have now. thanks for the heads on the fragility of the components.
