Jeep long start when hot engine
Once I figured out there were mopar clones out there, I didn't trust any of the ebay listings that had "too good to be true" pricing. OEM injectors from reputable sources are $100 each. I know the bosch ones I got are real.
I installed a diablo tune and it made no difference. If I unplug the map sensor, and the system goes "open loop" the misfires go away.
Hello, I bought my Wrangler JKU 2015 already with this same problem, long start only after more than 30 minutes stopped hot, I already measured the gasoline pressure and it is at 4 bar, I will follow your indication and change the 6 injectors.
I believe it to be an injector leaking by flooding the engine after sitting. Then when it sits overnight the vapors are gone. I have replaced everything but my injectors. If you change them let me know. krnl download
hdstreamz.uno
hdstreamz.uno
I replaced my injectors and it made no change. It may be better to spend money on an inline fuel pressure gauge so you can see if the pressure bleeds intead of goning through the effort of replacing injectors.
the same work around works for me. It’s annoying though because I can’t use remote start or it will do the long crank
